масло для Кавасаки KFX450
Model Identification
Year & Model ’08 KSF450B8F/B8FA:KFX450R
Color KSF450B8F
1. Colored Plastic Bright White (268)
2. Lime Green (777)
KSF450B8FA
1. Colored Plastic Super Black (839)
VIN Range JKASFGB1􀀖8B500001 -
Engine No. Range SF450BE500001 —
Engine No. Location LH crankcase, lower rear
Tuning Specifications
Engine
Spark Plug NGK CPR8EB-9
— Gap 0.8 - 0.9 mm (0.03-0.04 in.)
Ignition Timing 10° @ 1,800 rpm
Idle Speed N/A
Engine Oil API SF or SG, SAE 10W-40
Capacity 1.35 L (1.4 qt.)
Coolant 1.4 L (1.5 qt.)
Вот например. Это софициального сайта.
Это выдержка из спецификации.
http://www.kawasaki.com/DefaultFrame.as ... EHTABS%3d1
Color KSF450B8F
2. Lime Green (777)
KSF450B8FA
Engine
Idle Speed N/A
