DRZ400E - готовится на пенсию!
Модератор:Driverok
Вот и пришла замена DRZ400E!
[/img]
Не спеши - а то успеешь!
- arthurmoto1
07.01.2009 - Откуда:Житомир
да уж повеселее. и кубиков, вероятно, 450
А звідки фотка?
Може там і опис, тех дані є.
З вигляду RMZ+фара від WR
444 Enduro School
https://www.facebook.com/444EnduroSchool
- arthurmoto1
Думаю, это близнец КАВЫ KLX450.
Вот и спецификацию нашел
2010 Suzuki RMX450Z
Heart of a champion, a taste for adventure.
2010 Suzuki RMX450Z
Racing improves the breed; Suzuki has proven that time and time again. Now it’s time to rewrite the rules for the serious off-road rider. Introducing the 2010 Suzuki RMX450Z.
Descended from the Championship winning RM-Z450, the first motocross bike to offer high-performance Suzuki fuel injection, the RMX450Z is a serious off-road bike for serious trail riders. Its powerful and torquey 449cm3, liquid-cooled, four-stroke engine shares all core technology with Suzuki’s winning open-class motocrosser. Its frame, suspension and bodywork are all nearly identical to the RM-Z450’s—maintaining that model’s slim, aggressive styling. Only changes to make the RMX450Z a superior trail machine have been made—maximum performance – no compromises.
That’s like taking your hard-core motocross machine out onto the trail.
Only better. Much better.
Fuel Injection
Suzuki pioneered fuel injection for motocrossers, and the RMX450Z shares all key technologies with the stunning RM-Z450. Fuel injection improves fuel efficiency, throttle response and reduces emissions, allowing the RMX450Z to be “green sticker” eligible in the state of California. On every trail in the world, the RMX450Z’s fuel injection provides unmatched smoothness of power delivery and trail-ready reliability thanks to a KEIHIN throttle body with progressive linkage. This advanced fuel injection system also eliminates the need for re-jetting at higher elevations. To best suit the RMX450Z to life on the trail, the airbox features a hinged lid for quick air-filter maintenance and better protection from dust. Suzuki’s vast experience with motorcycle fuel injection both on and off-road help make this among the best systems available.
Electric Start
The trail is no place to wear yourself out kick-starting a bike, so the RMX450Z comes with an electric starter, energized by a compact battery centrally located to reduce its influence on weight distribution and balance of the bike. To charge the battery and power the RMX450Z’s lights, a larger magneto-generator is fitted. It’s a win-win situation.
Engine & Transmission
Suzuki has made minimal modifications to the all-conquering RM-Z450’s potent four-valve, DOHC engine for the RMX450Z. This lightweight engine now features a modified inlet tract along with revised cam profiles to increase low and mid-rpm power. Wider gear ratios in the 5-speed constant-mesh transmission that work with revised primary and final-drive ratios are ideally suited for a broad range of conditions, from scaling steep trails to high-speed open-terrain riding.
The addition of a coolant reservoir tank increases on-trail reliability, while a relocated filler cap improves access. Because the trail can be a rocky place, a new engine protector plate is fitted. No stone was left unturned.
State of the Art Chassis
Suzuki’s light and effective aluminum alloy twin-spar frame construction is used in the RMX450Z, employing both cast and extruded sections for the utmost benefits of both: low weight, high rigidity, and high durability. The RMX450Z’s aluminum alloy swingarm is derived from the RM-Z450’s to maintain ideal balance, while the rear suspension linkage benefits from reduced free play. Its geometry combines the RM series’ renowned turning-on-rails abilities with optimized handling performance that all serious trail riders want.
World Class Suspension
Derived from the RM-Z450, the RMX450Z’s trail ready suspension features the same phenomenal action as the race bike. The RMX450Z suspension utilizes high performance rebound and compression damping adjustable Showa forks combined with a Showa piggyback reservoir style rear shock featuring two-way adjustable compression damping with adjustable rebound damping and preload adjustments. Spring rates have been optimized for off-road riding. Every aspect of the RMX450Z’s performance envelope has been carefully considered for serious off-road riding without compromising a millimeter of quality.
Superior Ergonomics
Sit on an RM-Z450. Now go sit on the new RMX450Z. Feels just about the same, right? That’s right. With an ideal riding position resulting from the motocross-developed seat, slim bodywork and low-profile aluminum alloy fuel tank, the RMX450Z allows the rider to concentrate on the terrain. A comfortable rider is a fast rider.
Instruments You Need
A durable, ultra-compact enclosure houses a full-function instrument cluster on the RMX450Z—and can be configured for two modes, standard and sport. The sport mode simplifies the display so the rider can concentrate on terrain; it shows the timer, tripmeter, average speed and tire-diameter correction. In the standard mode, the display also shows speed, time, two trip lengths, and voltage. An integrated tire diameter calculator allows precise fine tuning for different tires to ensure accuracy of the speed and distance displays. The RMX450Z also features a low fuel level warning light for confident off-road riding anywhere you go.
2010 RMX450Z Technical Specifications
Overall Length 2,185 mm (86.0 in.)
Overall Width 830 mm (32.7 in.)
Overall Height 1,260 mm (50.0 in.)
Wheelbase 1,480 mm (58.3 in.)
Ground Clearance 320 mm (12.6 in.)
Seat Height 955 mm (37.6 in.)
Curb Weight 123.5 kg (272.3 lbs.)
Engine Type 4-stroke, liquid cooled, DOHC
Bore 96.0 mm
Stroke 62.1 mm
Displacement 449 cm³
Compression Ratio 11.6:1
Fuel System Fuel Injection
Lubrication System Suzuki Advanced Sump System
Clutch Wet multi-plate type
Starter Electric and Manual
Transmission 5-speed constant mesh
Primary Reduction Ratio 2.708 (65/24)
Gear Ratios 1st 2.153 (28/13)
2nd 1.611 (29/18)
3rd 1.250 (25/20)
4th 1.000 (19/19)
5th 0.826 (19/23)
Final Reduction Ratio 3.923 (51/13)
Front Suspension SHOWA 47mm telescopic forks, pneumatic/coil spring, oil
damped
Rear Suspension Swingarm, link type, SHOWA piggyback-reservoir shock
Caster 29°18’
Trail 130mm (5.1 in.)
Front Brake Disc
Rear Brake Disc
Front Tire Size 80/100-21
Rear Tire Size 110/100-18
Fuel Tank Capacity 6.2 L (1.6 US gal.)
Body Color Sold Black/Champion Yellow No. 2 (GY8)
2010 Suzuki RMX450Z
2010 Suzuki RMX450Z
Fuel Injection
Electric Start
Superior Ergonomics
Bore 96.0 mm
Stroke 62.1 mm
2nd 1.611 (29/18)
3rd 1.250 (25/20)
4th 1.000 (19/19)
5th 0.826 (19/23)
damped
Caster 29°18’
Front Brake Disc
Rear Brake Disc
6,2 литра бак -- для эндурика 450сс это мало, даже если там инжектор
Вот тут можно почитать.
http://www.motorcyclespecs.co.za/model/ ... mx450z.htm
Тут - посмотреть фото.
http://www.motorcycle-usa.com/1545/Moto ... dels-.aspx
сдя по весу это тренажор для похудения.
- A.T. aka Various
24.02.2007 - Откуда:Украина, Киев
Уж больно на кроссовый стал похож...
Поживём увидим, а увидим будем жить дальше...
Так це і є кросак RMZ 450 з іншою коробкою, допрацьованим двиглом і світлом.
Давно пора було його випустити, а то DRZ хоч і надійний мотик але важкуватий.
444 Enduro School
- Igorexa_la
RMX 450 yje poyavilis v prodaje
Skype Igorexa_la
- Vitaha1985
06.03.2012 - Откуда:СССР
Да уж тяжеловат СУКО,
ПУСТЬ ЛУЧШЕ в мышцах будет боль. Чем наркота и алкоголь!!!
